need help
ramdon
thanks for the informations but cand u pont out the codes that i need to look up and what filles they are in as u can see the Navigation meanu and Client Login has a big space under then wach sould not bee there and i cant seem to move up the Welcome to our Support Area up even if i make more space for it to fit it will not move up thats my mann problems im haveing
i would like some one to tell me the codes to get this sorted out if u what my header.tpl then ill add a url for u to down load and have a look at it
thanks
