Problems Restoring DB
bugster
I'm trying to move the whmcs db to a different server. I do a backup using whmcs and then try importing it using the mysql command. I keep getting an error:
ERROR 1292 <22007> at line 8764: Incorrect date value: ' ' for column 'duedate' at row 1
My backup file is over 11mb so finding the problem is a little tricky and I've searched for 'duedate' in the file and can't even find a mention of it.
Any help would be appreciated. I'm just glad I found the problem now and not when I needed to restore from a crash. I'm using ver 3.6.2
Thanks,
Brian
