leew87 Posted November 17, 2008 Share Posted November 17, 2008 hi i wonder if anyone can help i am trying to follow a tutorial found at http://www.fpdf.org/ using the following code to load in a file and display it on my invoice require('fpdf.php'); class PDF extends FPDF { function Header() { global $title; //Arial bold 15 $this->SetFont('Arial','B',15); //Calculate width of title and position $w=$this->GetStringWidth($title)+6; $this->SetX((210-$w)/2); //Colors of frame, background and text $this->SetDrawColor(0,80,180); $this->SetFillColor(230,230,0); $this->SetTextColor(220,50,50); //Thickness of frame (1 mm) $this->SetLineWidth(1); //Title $this->Cell($w,9,$title,1,1,'C',true); //Line break $this->Ln(10); } function Footer() { //Position at 1.5 cm from bottom $this->SetY(-15); //Arial italic 8 $this->SetFont('Arial','I',; //Text color in gray $this->SetTextColor(128); //Page number $this->Cell(0,10,'Page '.$this->PageNo(),0,0,'C'); } function ChapterTitle($num,$label) { //Arial 12 $this->SetFont('Arial','',12); //Background color $this->SetFillColor(200,220,255); //Title $this->Cell(0,6,"Chapter $num : $label",0,1,'L',true); //Line break $this->Ln(4); } function ChapterBody($file) { //Read text file $f=fopen($file,'r'); $txt=fread($f,filesize($file)); fclose($f); //Times 12 $this->SetFont('Times','',12); //Output justified text $this->MultiCell(0,5,$txt); //Line break $this->Ln(); //Mention in italics $this->SetFont('','I'); $this->Cell(0,5,'(end of excerpt)'); } function PrintChapter($num,$title,$file) { $this->AddPage(); $this->ChapterTitle($num,$title); $this->ChapterBody($file); } } $pdf=new PDF(); $title='Terms And Conditions'; $pdf->SetTitle($title); $pdf->SetAuthor(ILL IT Solutions); $pdf->PrintChapter(1,'Terms And Conditions','T&C.txt'); $pdf->Output(); can anyone help i am trying to create an invoice that looks like my current 1 found at http://www.illit.co.uk/ILLITInvoice.pdf thanks in advance Lee 0 Quote Link to comment Share on other sites More sharing options...
