Few problems
Lee
I have just download WHM and uploaded all the files.
I have run the install file and get this error message:
INSTALL/UPGRADE WHMCS V2.5.8
Preinstallation System Checks
PHP Version .......... Passed
MySQL .......... Passed
Register Globals .......... WHMCS requires Register Globals to be On for it function correctly. These can be enabled in a .htaccess or php.ini file in your WHMCS Directory.
Configuration File .......... Passed
Attachments Folder Permissions .......... Passed
Downloads Folder Permissions .......... Passed
Templates Folder Permissions .......... Passed
Announcements RSS File .......... Passed
Error! Some Preinstallation Checks Failed. You must correct the errors above before you can continue with installation.
I have uploaded the .htaccess file for the register globals but still no luck.
Can some one help please?
What have you entered in your .htaccess file to enable register globals? Entering the correct value in a .htaccess file usually either results in register globals being enabled or an Internal Server Error.
Matt
This is what i have added....
php_value register_globals on
