tomdchi Posted September 20, 2008 Share Posted September 20, 2008 I want the ability to upload docs tied to a client. I have been able to put a form into clientsummary.tpl that will do this into a table called upload. The problem I am having is getting the userid to pass through to the php script. I have tried a bunch of trial and error but no luck. The files do upload fine but there is no userid in the userid field on the db. Can someone take a look and hopefully tell me what I am missing. Still a noob but learning:-) Thanks, Tom Here is the form that I have inserted into clientsummary.tpl: <form method="post" enctype="multipart/form-data" action="https://mydomain.com/resident/upload.php"> <table width="350" border="0" cellpadding="1" cellspacing="1" class="box"> <tr> <td width="246"> <input type="hidden" name="MAX_FILE_SIZE" value="2000000"> <input name="userfile" type="file" id="userfile"> <input name="userid" style="height: 22px" type="hidden" value="{$clientdetails.userid}"></td> <td width="80"><input name="upload" type="submit" class="box" id="upload" value=" Upload "></td> </tr> </table> </form> The contents of upload.php file: <?php include("dbconnect.php"); include("includes/functions.php"); if(isset($_POST['upload'])) { $fileName = $_FILES['userfile']['name']; $tmpName = $_FILES['userfile']['tmp_name']; $fileSize = $_FILES['userfile']['size']; $fileType = $_FILES['userfile']['type']; $userid = $_POST['userid']['userid']; // i have tried many variations for the above variable $userid but I think its wrong $fp = fopen($tmpName, 'r'); $content = fread($fp, $fileSize); $content = addslashes($content); fclose($fp); if(!get_magic_quotes_gpc()) { $fileName = addslashes($fileName); } $query = "INSERT INTO upload (userid, name, size, type, content ) ". "VALUES ('$userid', '$fileName', '$fileSize', '$fileType', '$content')"; mysql_query($query) or die('Error, query failed'); echo "<br>File $fileName uploaded<br>"; } ?> 0 Quote Link to comment Share on other sites More sharing options...
tomdchi Posted September 21, 2008 Author Share Posted September 21, 2008 Now I need to be able to download these. The script I have picks up the first document in the database for the client but not others and opens up a box to open or save. I want it to bring up a new window displaying all filenames for the given userid with a hyperlink. Can anyone help with this? Here is what I am using now: I access the file below from the admin with a link: download.php?userid={$clientsdetails.userid} <?php if(isset($_GET['userid'])) { include("../dbconnect.php"); include("../includes/functions.php"); $userid = $_GET['userid']; $query = "SELECT name, type, size, content FROM upload WHERE userid = '$userid'"; $result = mysql_query($query) or die('Error, query failed'); list($name, $type, $size, $content) = mysql_fetch_array($result); header("Content-Disposition: attachment; filename=$name"); header("Content-length: $size"); header("Content-type: $type"); echo $content; exit; } ?> <html> <head> <title>Download File From MySQL</title> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"> </head> <body> <?php include("../dbconnect.php"); include("../includes/functions.php"); $query = "SELECT * upload WHERE userid = '$userid'"; $result = mysql_query($query) or die('Error, query failed'); if(mysql_num_rows($result) == 0) { echo "Database is empty <br>"; } else { while(list($userid, $name) = mysql_fetch_array($result)) { ?> <a href="download.php?id=<?=$id;?>"><?=$name;?></a> <br> <? } } ?> </body> </html> What I did to make upload function in admin: Create table: CREATE TABLE upload ( id INT NOT NULL AUTO_INCREMENT, userid INT NOT NULL, name VARCHAR(30) NOT NULL, type VARCHAR(30) NOT NULL, size INT NOT NULL, content MEDIUMBLOB NOT NULL, PRIMARY KEY(id) ); Insert this form into the clientsummary.tpl located at admin/templates/clientsummary.tpl: <form method="post" enctype="multipart/form-data" action="upload.php"> <table width="350" border="0" cellpadding="1" cellspacing="1" class="box"> <tr> <td width="246"> <a href="download.php?userid={$clientsdetails.userid}">view documents</a></td> <td width="80"> </td> </tr> <tr> <td width="246"> <input type="hidden" name="userid" value="{$clientsdetails.userid}"> <input type="hidden" name="MAX_FILE_SIZE" value="2000000"> <input name="userfile" type="file" id="userfile"> </td> <td width="80"><input name="upload" type="submit" class="box" id="upload" value=" Upload "></td> </tr> </table> </form> then put the contents of this into a file named upload.php and put it into the admin directory. <?php include("../dbconnect.php"); include("../includes/functions.php"); $userID = addslashes($_POST['userid']); if(!empty($_POST['upload'])) { $fileName = $_FILES['userfile']['name']; $tmpName = $_FILES['userfile']['tmp_name']; $fileSize = $_FILES['userfile']['size']; $fileType = $_FILES['userfile']['type']; $fp = fopen($tmpName, 'r'); $content = fread($fp, $fileSize); $content = addslashes($content); fclose($fp); if(!get_magic_quotes_gpc()) { $fileName = addslashes($fileName); } $query = "INSERT INTO upload (userid, name, size, type, content ) ". "VALUES ('$userID', '$fileName', '$fileSize', '$fileType', '$content')"; mysql_query($query) or die('Error, query failed'); echo "<br>File $fileName uploaded<br>"; echo "User ID: $userID <br />"; } ?> The echo statements where a debugging tool I was using to make sure that the proper values where being sent to the db. I plan to take them out when everything is set the way I want them. 0 Quote Link to comment Share on other sites More sharing options...
tomdchi Posted September 24, 2008 Author Share Posted September 24, 2008 This has been solved and I have posted files here: http://forum.whmcs.com/showthread.php?t=14398 if anyone needs this. 0 Quote Link to comment Share on other sites More sharing options...
