madriguera Posted August 31, 2008 Share Posted August 31, 2008 Hi, In the lasts weeks the system of whmcs has problems with the domains .MX in the option of Domain Availability Lookup, all the names of domains .com.mx show is not avaliable, but if you search in the web of nic.mx the domains are avaliable: Example look in the system of whmcs the next name: jhs76dysahsgd.com.mx if you can see the system of whmcs is show me that this domain is not avaliable but if you look in the web of http://www.nic.mx the same domain name is avaliable for registration. Thanks. 0 Quote Link to comment Share on other sites More sharing options...
screege Posted August 31, 2008 Share Posted August 31, 2008 was it working for you before? I have the same problem, but just installed the software, I used to use modernbill 4 and it works with it, I even have the same config as in modern bill but it does not works in whmcs 0 Quote Link to comment Share on other sites More sharing options...
MACscr Posted September 1, 2008 Share Posted September 1, 2008 Obviously you need to adjust the whois server list located in your includes/ folder. 0 Quote Link to comment Share on other sites More sharing options...
screege Posted September 1, 2008 Share Posted September 1, 2008 Well I have done it and no it is not working 0 Quote Link to comment Share on other sites More sharing options...
Hosteris Posted September 1, 2008 Share Posted September 1, 2008 Say thanks to uncle BotHaTe Solution to this problem:edit "../whmcsdirectory/includes/whoisservers.php" find this code: .mx|whois.nic.mx|Referencias de Organization No Encontradas .com.mx|whois.nic.mx|Referencias de Organization No Encontradas .org.mx|whois.nic.mx|Referencias de Organization No Encontradas .net.mx|whois.nic.mx|Referencias de Organization No Encontradas .edu.mx|whois.nic.mx|Referencias de Organization No Encontradas .gov.mx|whois.nic.mx|Referencias de Organization No Encontradas .gob.mx|whois.nic.mx|Referencias de Organization No Encontradas Change it to: .mx|whois.nic.mx|No_Se_Encontro_El_Objeto/Object_Not_Found .com.mx|whois.nic.mx|No_Se_Encontro_El_Objeto/Object_Not_Found .org.mx|whois.nic.mx|No_Se_Encontro_El_Objeto/Object_Not_Found .net.mx|whois.nic.mx|No_Se_Encontro_El_Objeto/Object_Not_Found .edu.mx|whois.nic.mx|No_Se_Encontro_El_Objeto/Object_Not_Found .gov.mx|whois.nic.mx|No_Se_Encontro_El_Objeto/Object_Not_Found .gob.mx|whois.nic.mx|No_Se_Encontro_El_Objeto/Object_Not_Found And whois will work The problem is that nic.mx make some changues on the whois output...but no one receive info about that :-/ Have a nice day *sorry for my bad english* 0 Quote Link to comment Share on other sites More sharing options...
screege Posted September 1, 2008 Share Posted September 1, 2008 Thanks a lot now its working fine. 0 Quote Link to comment Share on other sites More sharing options...
charliez Posted September 1, 2008 Share Posted September 1, 2008 Thanks bothate 0 Quote Link to comment Share on other sites More sharing options...
chatyss Posted September 17, 2008 Share Posted September 17, 2008 Thanks uncle BotHaTe 0 Quote Link to comment Share on other sites More sharing options...
