Right way to add domain pricing
Vincent Vega
I'm trying to cofigure my WHMCS install in the right way, but I still get something strange when checking multiple domains:
As you can see there is no dot between the domainname and the tld and the first (.nl) is checked again but this time without a dot.
Is does not matter if I change in admin the tld with or without a dot.
After making the change in the domain pricing to include the preceeding . you need to also update the bulk check TLDs setting you have in General Settings > Domains as that remains wrong until you update it.
Matt
  • 4 weeks later...
