henwijaya Posted October 8, 2006 Share Posted October 8, 2006 Is there anyone here having problem with cron? I put everything like it says on the manual or setup screen for cron but I got this message from email report. PHP Warning: main(dbconnect.php): failed to open stream: No such file or directory in /home/-/public_html/-/-/cron.php on line 5 PHP Warning: main(dbconnect.php): failed to open stream: No such file or directory in /home/-/public_html/-/-/cron.php on line 5 PHP Warning: main(dbconnect.php): failed to open stream: No such file or directory in /home/-/public_html/-/-/cron.php on line 5 PHP Fatal error: main(): Failed opening required 'dbconnect.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/-/public_html/-/-/cron.php on line 5 0 Quote Link to comment Share on other sites More sharing options...
Adam Posted October 9, 2006 Share Posted October 9, 2006 Hey, First of all home/-/public_html/-/-/cron.php is not any folder on your server. So make sure you have setup the right URL in cron jobs. Second, make sure all your files have been uploaded. The error you are getting is saying the file in your root whmcs folder dbconnect.php does not exist, or you uploaded it via binary (1010) mode. From, Adam 0 Quote Link to comment Share on other sites More sharing options...
henwijaya Posted October 9, 2006 Author Share Posted October 9, 2006 Problem was Ioncube had to be installed server wide. Its now fixed. 0 Quote Link to comment Share on other sites More sharing options...
