chaddsuk Posted May 14, 2008 Share Posted May 14, 2008 Hi i have tried to integrate clientarea.php into my website using the following code.. <?php include "./php/whmcs/clientarea.php"; ?> this is the client area... http://www.phphosts.co.uk/php/whmcs/clientarea.php as you can see it works fine, however when you visit http://www.phphosts.co.uk/client.php it doesnt pull through the form... anyone any idea what is causing this issue? cheers chris 0 Quote Link to comment Share on other sites More sharing options...
mylove4life Posted May 15, 2008 Share Posted May 15, 2008 there is a lot of stuff that nees to be called when using the pages in WHMCS system. I'd just add a page and make a template for it. 0 Quote Link to comment Share on other sites More sharing options...
BAJI26 Posted May 15, 2008 Share Posted May 15, 2008 Dunno if this is possible but its an idea, see if you can edit this code to accomplish what you require: http://wiki.whmcs.com/Linking_to_WHMCS Look to the bottom the announcement code. 0 Quote Link to comment Share on other sites More sharing options...
