Tooltip help with Custom fields
Zorro67
Hi guys,
i wonder if there are any coding genieii* (is that the correct spelling for the collective plural?)
that could help me with tool tips for custom fields within WHMCS.
I don't have many yet, but I'm planning to add 100-150 custom fields in the next week
I know there are 90 ways to enter tooltips (add to mysql, etc), but i have taken the easy way out and added them to the English.txt file as
$_LANG["tooltipcompanyname"] = "What is your \'Trading As\' name?";
I have the tooltip code entered into the relevant space of each .TPL file
eg in client register.tpl, at the point of the @@@
<tr><td class="fieldarea">{$LANG.clientareacompanyname}</td><td><input type="text" name="companyname" size=30 value="{$clientcompanyname}"> @@@ </td></tr>
I have added <a href="#" onmouseover="Tip('{$LANG.tooltipcompanyname}')"><img src="/support/images/clientarea/helpsm2.png" border="0" alt="tooltip"/></a>
Works really well. Then i got to custom fields.
I believe I can define it as
$_LANG["tooltip<pluscustomlabelname>"] = "Insert relevant text here";
but i'm not sure of the coding to lookup a custom string within a {foreach} routine.
<a href="#" onmouseover="Tip('{$LANG.<get the name of the tooltipcustomlabelhere>}')">
has anyone got an easy solution?
  • 5 weeks later...
