problem in using get_template_vars
amol.karande
I ma using get_template_vars() function in my .php file which I have in .tpl using {fetch file ,but in this I am facing problem that I can get few varibles but not all e.g $companyname,$currency these are single values but in single values also field $pagetitle I am not able to get
Also tell syntax to access array fields as $products is array so what should I use with get_template_vars()
