Display Stock for Products
RPS
This code will take a product id and display the stock, if stock is 0, then it will display an out of stock message.
This is useful if you have a product for sale on your website and would like to show everyone the stock available.
Put this code somewhere within your php page:
<?php
# path can be:
# /home/user/public_html/whmcs/configuration.php
# ../whmcs/configuration.php
# whmcs/configuration.php
# etc..
require('whmcs/configuration.php');
mysql_connect($db_host, $db_username, $db_password) or die(mysql_error());
mysql_select_db($db_name) or die(mysql_error());
# be sure to modify the 39 and use the product id you wish to display, this is the pid variable found on the shopping cart order link of the product details
$result = mysql_query("SELECT qty FROM tblproducts WHERE id = 39 AND stockcontrol = 'on'");
$row = mysql_fetch_row($result);
$qty_39 = "(".$row[0]." in stock)";
Use this code whenever you would like to display the product stock.
<?php if(!$row[0]) echo $out_of_stock; else echo $qty_39; ?>
