Slaweally Posted January 14 Share Posted January 14 Hello dear friends, After the latest version of Whmcs, I get url conversion errors in the knowledge base and announcements section. It does not convert Turkish characters, so it makes problems in these daurls. This problem has just started to happen recently and it was not the case in the past. Also as a suggestion; Is there a possibility to manually adjust the slug part of the content written to the announcement and knowledge base? 0 Quote Link to comment Share on other sites More sharing options...
Solution Slaweally Posted January 14 Author Solution Share Posted January 14 I solved the problem using the following configuration for the Nginx server. friends who have the same problem can use the following configuration. server { listen 80; listen [::]:80; listen 443 ssl http2; listen [::]:443 ssl http2; {{ssl_certificate_key}} {{ssl_certificate}} server_name www.orneksite.com; return 301 https://orneksite.com$request_uri; } server { listen 80; listen [::]:80; listen 443 ssl http2; listen [::]:443 ssl http2; {{ssl_certificate_key}} {{ssl_certificate}} server_name orneksite.com www1.orneksite.com; {{root}} charset utf-8; {{nginx_access_log}} {{nginx_error_log}} # Redirect directories to an address with slash if (-d $request_filename) { return 301 $uri/; } # Transliterate Türkçe karakterler içeren URL'leri ASCII karşılıklarıyla yeniden yazma rewrite ^/(.*)ç(.*)$ /$1c$2 permanent; rewrite ^/(.*)Ç(.*)$ /$1C$2 permanent; rewrite ^/(.*)ğ(.*)$ /$1g$2 permanent; rewrite ^/(.*)Ğ(.*)$ /$1G$2 permanent; rewrite ^/(.*)ı(.*)$ /$1i$2 permanent; rewrite ^/(.*)İ(.*)$ /$1I$2 permanent; rewrite ^/(.*)ş(.*)$ /$1s$2 permanent; rewrite ^/(.*)Ş(.*)$ /$1S$2 permanent; rewrite ^/(.*)ö(.*)$ /$1o$2 permanent; rewrite ^/(.*)Ö(.*)$ /$1O$2 permanent; rewrite ^/(.*)ü(.*)$ /$1u$2 permanent; rewrite ^/(.*)Ü(.*)$ /$1U$2 permanent; # HTTP'den HTTPS'ye yönlendirme if ($scheme != "https") { return 301 https://$host$request_uri; } location ~ /.well-known { auth_basic off; allow all; } {{settings}} try_files $uri $uri/ /index.php?$args; index index.php index.html; location / { error_page 404 /index.php?$query_string; try_files $uri $uri/ /index.php?$query_string; } # WHMCS managed rules - Nginx uyarlaması # BEGIN - WHMCS managed rules - DO NOT EDIT BETWEEN WHMCS MARKERS ### # WHMCS için özel yönlendirme kuralları location ~ ^/(announcements|download|knowledgebase|store/ssl-certificates|store/sitelock|store/website-builder|store/order|cart/domain/renew|account/paymentmethods|password/reset|account/security|subscription|auth/provider/google_signin/finalize)/?(.*)$ { rewrite ^/(.*)$ /index.php?rp=/$1/$2 last; } # WHMCS admin panel için özel yönlendirme kuralları location ~ ^/AdminPanel/(addons|apps|search|domains|help/license|services|setup|utilities/system/php-compat)/?(.*)$ { rewrite ^/AdminPanel/(.*)$ /AdminPanel/index.php?rp=/admin/$1 last; } location ~ ^/AdminPanel/client/(.*)/paymethods/(.*)$ { rewrite ^/AdminPanel/client/(.*)/paymethods/(.*)$ /AdminPanel/index.php?rp=/client/$1/paymethods/$2 last; } location ~ ^/AdminPanel/setup/auth/(.*)$ { rewrite ^/AdminPanel/setup/auth/(.*)$ /AdminPanel/index.php?rp=/setup/auth/$1 last; } location ~ ^/AdminPanel/client/(.*)/tickets/(.*)$ { rewrite ^/AdminPanel/client/(.*)/tickets/(.*)$ /AdminPanel/index.php?rp=/client/$1/tickets/$2 last; } location ~ ^/AdminPanel/client/(.*)/invoice/(.*)/capture/(.*)$ { rewrite ^/AdminPanel/client/(.*)/invoice/(.*)/capture/(.*)$ /AdminPanel/index.php?rp=/client/$1/invoice/$2/capture/$3 last; } location ~ ^/AdminPanel/account/security/two-factor/(.*)$ { rewrite ^/AdminPanel/account/security/two-factor/(.*)$ /AdminPanel/index.php?rp=/admin/account/security/two-factor/$1 last; } location ~ ^/AdminPanel/search/intellisearch/(.*)$ { rewrite ^/AdminPanel/search/intellisearch/(.*)$ /AdminPanel/index.php?rp=/search/intellisearch/$1 last; } # END - WHMCS managed rules - DO NOT EDIT BETWEEN WHMCS MARKERS ### location ^~ /vendor/ { deny all; return 403; } location ~ \.php$ { include fastcgi_params; fastcgi_intercept_errors on; fastcgi_index index.php; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; try_files $uri =404; fastcgi_read_timeout 3600; fastcgi_send_timeout 3600; fastcgi_param HTTPS $fastcgi_https; fastcgi_pass 127.0.0.1:{{php_fpm_port}}; fastcgi_param PHP_VALUE "{{php_settings}}"; } location ~* ^.+\.(css|js|jpg|jpeg|gif|png|ico|gz|svg|svgz|ttf|otf|woff|woff2|eot|mp4|ogg|ogv|webm|webp|zip|swf)$ { add_header Access-Control-Allow-Origin "*"; expires max; access_log off; } if (-f $request_filename) { break; } } Do not forget to edit the admin panel and site address according to yourself. 0 Quote Link to comment Share on other sites More sharing options...
Kane William Posted January 16 Share Posted January 16 I was also facing the same issue with the latest version. Thank you so much for sharing the solution. Highly appreciated! 0 Quote Link to comment Share on other sites More sharing options...
