Daily Cron problem
Brain
Hello
I'm getting error in daily cron. I couldn't find any information how to fix this on community or google.
Version of whmcs -  8.10.1, php - 7.4
Here is output:
root@mail:/etc# /usr/bin/php7.4 -q /home/admin/web/site.site/public_html/crons/cron.php -F -vvv
WHMCS Automation Task Utility: all
 Daily Cron Automation Mode
Queuing Tasks
 Force run any tasks: ignore "in progress" and "is due"
 Task queues ready
Executing Application Queue
  0/35 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░]   0% < 1 sec/< 1 sec 30.0 MiB
 Currency Exchange Rates
  1/35 [░░░░░░░░░░░░░░░░░░░░░░░░░░░░]   2% < 1 sec/< 1 sec 30.0 MiB
 Product Pricing Updates
  2/35 [▓░░░░░░░░░░░░░░░░░░░░░░░░░░░]   5% < 1 sec/< 1 sec 30.0 MiB
 Tenant Usage Metrics
  3/35 [▓▓░░░░░░░░░░░░░░░░░░░░░░░░░░]   8% < 1 sec/< 1 sec 30.0 MiB
 Invoices
  4/35 [▓▓▓░░░░░░░░░░░░░░░░░░░░░░░░░]  11%  1 sec/9 secs 30.0 MiB
 Late Fees
  5/35 [▓▓▓▓░░░░░░░░░░░░░░░░░░░░░░░░]  14%  1 sec/7 secs 30.0 MiB
 Credit Card Charges
  6/35 [▓▓▓▓░░░░░░░░░░░░░░░░░░░░░░░░]  17%  1 sec/6 secs 32.0 MiB
 Invoice & Overdue Reminders
  7/35 [▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░░░░]  20% 4 secs/20 secs 52.5 MiB
 Domain Renewal Notices
  8/35 [▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░░░]  22% 4 secs/18 secs 52.5 MiB
 Cancellation Requests
  9/35 [▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░░]  25% 4 secs/16 secs 52.5 MiB
 Overdue Suspensions
 10/35 [▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░]  28% 4 secs/14 secs 52.5 MiB
 Overdue Terminations
 11/35 [▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░░]  31% 4 secs/13 secs 52.5 MiB
 Fixed Term Terminations
 12/35 [▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░░]  34% 4 secs/12 secs 52.5 MiB
 Overdue Invoice Cancellations
 13/35 [▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░░]  37% 5 secs/13 secs 52.5 MiB
 Inactive Tickets
 14/35 [▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░░]  40% 5 secs/13 secs 52.5 MiB
 Prune Ticket Attachments
 15/35 [▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░]  42% 5 secs/12 secs 52.5 MiB
 Delayed Affiliate Commissions
 16/35 [▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░░]  45% 5 secs/11 secs 52.5 MiB
 Affiliate Reports
 17/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░░]  48% 5 secs/10 secs 52.5 MiB
 Process Email Campaigns
 18/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░░]  51% 5 secs/10 secs 52.5 MiB
 Process Email Queue
 19/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░░]  54% 5 secs/9 secs 52.5 MiB
 Email Marketer Rules
 20/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░]  57% 5 secs/9 secs 52.5 MiB
 SSL Sync
 21/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░░]  60% 4 mins/7 mins 52.5 MiB
 Credit Card Expiry Notices
 22/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░░]  62% 4 mins/7 mins 52.5 MiB
 Server Usage Stats
 23/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░░]  65% 4 mins/7 mins 52.5 MiB
 Overage Billing Charges
 24/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░░]  68% 4 mins/6 mins 52.5 MiB
 Client Status Update
 25/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░]  71% 4 mins/6 mins 52.5 MiB
 Domain Expiry
 26/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░░]  74% 4 mins/6 mins 52.5 MiB
 Ticket Escalation Rules
 27/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░░]  77% 4 mins/6 mins 54.5 MiB
 Data Retention Pruning
 28/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░░]  80% 4 mins/5 mins 54.5 MiB
 SSL Certificate Reissues
 29/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░░]  82% 4 mins/5 mins 54.5 MiB
 Update Server Usage
 30/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░]  85% 4 mins/5 mins 54.5 MiB
 Update Server Meta Data
 31/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░░]  88% 4 mins/5 mins 54.5 MiB
 Run Jobs Queue
 32/35 [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓░░░]  91% 4 mins/5 mins 54.5 MiB
 WHMCS Updates
PHP Fatal error:  Class Composer\Semver\Constraint\EmptyConstraint contains 3 abstract methods and must therefore be declared abstract or implement the remaining methods (Composer\Semver\Constraint\ConstraintInterface::compile, Composer\Semver\Constraint\ConstraintInterface::getUpperBound, Composer\Semver\Constraint\ConstraintInterface::getLowerBound) in /home/admin/web/site.site/public_html/vendor/composer/semver/src/Constraint/EmptyConstraint.php on line 17
[WHMCS Application] ERROR: Whoops\Exception\ErrorException: Class Composer\Semver\Constraint\EmptyConstraint contains 3 abstract methods and must therefore be declared abstract or implement the remaining methods (Composer\Semver\Constraint\ConstraintInterface::compile, Composer\Semver\Constraint\ConstraintInterface::getUpperBound, Composer\Semver\Constraint\ConstraintInterface::getLowerBound) in /home/admin/web/site.site/public_html/vendor/composer/semver/src/Constraint/EmptyConstraint.php:17 Stack trace: #0 /home/admin/web/site.site/public_html/vendor/whmcs/whmcs-foundation/lib/Utility/Error/Run.php(0): WHMCS\Utility\Error\Run->handleError(1, 'Class Composer\\...', '/home/admin/web...', 17) #1 [internal function]: WHMCS\Utility\Error\Run->handleShutdown() #2 {main} {"exception":"[object] (Whoops\\Exception\\ErrorException(code: 1): Class Composer\\Semver\\Constraint\\EmptyConstraint contains 3 abstract methods and must therefore be declared abstract or implement the remaining methods (Composer\\Semver\\Constraint\\ConstraintInterface::compile, Composer\\Semver\\Constraint\\ConstraintInterface::getUpperBound, Composer\\Semver\\Constraint\\ConstraintInterface::getLowerBound) at /home/admin/web/site.site/public_html/vendor/composer/semver/src/Constraint/EmptyConstraint.php:17)"} []
#2 {main}root@mail:/etc#
Update
I found second problem
I got error in WHMCS:
Cron PHP Version Mismatch
Your environment appears to be running a different PHP version (7.2.34-51+0~20240802.96+debian12~1.gbpe3aa6e) for the System Cron than the currently loaded PHP version (8.1.29). This may cause issues running your System Cron.
But i dont have php 7.2 on server
And i run cron task with this command */5 * * * * root /usr/bin/php8.1 -q /home/admin/web/site.site/private/crons/cron.php
  • 3 months later...
