Add clients to custom group based on product...
EdH
I have been trying to setup my WHMCS instance to automatically assign clients to a client group, based on the product.
I have found a code hook from Katamaze, which seems to have worked previously but it now throws an error as below on PHP 8.1 with WHMCS 8.8 - seems there was a vulnerability patched that resulted in some changed code in the new PHP, which has broken this HOOK.
TypeError: array_keys(): Argument #1 ($array) must be of type array, Illuminate\Support\Collection given in /home/cpaneluser/includes/hooks/assign-client-group-based-on-product.php:30
Stack trace:
#0 /home/cpaneluser/includes/hooks/assign-client-group-based-on-product.php(30): array_keys()
#1 [internal function]: WHMCS\Utility\SafeInclude::{closure}()
#2 /home/cpaneluser/vendor/whmcs/whmcs-foundation/lib/Hook/Manager.php(0): call_user_func()
#3 /home/cpaneluser/vendor/illuminate/support/Facades/Facade.php(261): WHMCS\Hook\Manager->run()
#4 /home/cpaneluser/includes/functions.php(0): Illuminate\Support\Facades\Facade::__callStatic()
#5 /home/cpaneluser/includes/orderfunctions.php(0): run_hook()
#6 /home/cpaneluser/admin/orders.php(0): acceptOrder()
#7 {main}
If anybody can suggest a tweak to this code, which will get it working - or perhaps another way to add new clients into a group automatically, it would be much appreciated!
<?php
 * Assign Client to Group based on purchased Product/Service v1
 * @package     WHMCS
 * @copyright   Katamaze
 * @link        https://katamaze.com
 * @author      Davide Mantenuto <info@katamaze.com>
use WHMCS\Database\Capsule;
add_hook('AcceptOrder', 1, function($vars)
    // Define group/product pairs. Instructions provided below
    // https://github.com/Katamaze/WHMCS-Free-Action-Hooks/blob/master/README.md#client-to-group-based-on-purchased-productservice
    $groups['products']['5'] = array('3', '18', '16', '5','6','7','8','9','10','11','12','13','14','15','19');
    $groups['products']['6'] = array('75','76');
    $groups['productaddons']['0'] = array('0');
    $groups['configurableoption']['0'] = array('0' => array('0'), '' => true);
    if (!$groups): return; endif;
    $userID = Capsule::table('tblorders')->where('id', $vars['orderid'])->pluck('userid')[0];
    $orderedProducts = Capsule::table('tblhosting')->where('orderid', $vars['orderid'])->pluck('packageid', 'id');
    $orderedProductAddons = Capsule::table('tblhostingaddons')->where('orderid', $vars['orderid'])->pluck('addonid');
    if ($groups['configurableoption'])
        foreach (Capsule::select(Capsule::raw('SELECT t1.relid, t1.configid, t1.optionid, t1.qty, t2.optiontype FROM tblhostingconfigoptions as t1 LEFT JOIN tblproductconfigoptions AS t2 ON t1.configid = t2.id LEFT JOIN tblproductconfigoptionssub AS t3 ON t1.optionid = t3.id WHERE t1.relid IN (\'' . implode('\',\'', array_keys($orderedProducts)) . '\')')) as $v)
            $relid = $v->relid;
            $configid = $v->configid;
            if (in_array($v->optiontype, array('3', '4')))
                $value = ($v->qty ? true : false);
            else
                $value = $v->optionid;
            unset($v);
            if ($value)
                $orderedConfigurableOptions[$relid][$configid] = $value;
    foreach ($groups['products'] as $group => $target)
        if (array_intersect($orderedProducts, $target))
            Capsule::table('tblclients')->where('id', $userID)->where('groupid', '0')->update(['groupid' => $group]);
            return;
    foreach ($groups['productaddons'] as $group => $target)
        if (array_intersect($orderedProductAddons, $target))
            return;
    foreach ($groups['configurableoption'] as $group => $configurableOptions)
        foreach ($configurableOptions as $configID => $options)
            if (is_array($options))
                foreach ($orderedConfigurableOptions as $target)
                    if (array_intersect($options, $target))
                        return;
            else
                    if (in_array($configID, $target))
                        return;
