  • 0
WHMCS Bridge does not work with CloudFlare?
Mustapha
Question
hello i have this problem:
  • Cache check results: Cache headers found in HTTP requests. CloudFlare detected. Please note WHMCS Bridge does not work with CloudFlare, please either revert to your original name servers (sometimes this is the only option), or completely disable CloudFlare and all it's services on your bridge URL (yourdomain.tld/yourwhmcsbridgepage/*)
    If you are making changes (eg: whmcs template) and it's not updating your WHMCS bridge page, or if you are seeing other users details when logged in (or logged in users details without logging in) then you need to please disable cache for the whmcs bridge page and all child pages.
    Most good cache plugins allow you to specify a directory / url keyword to exclude from caching; simply add your /whmcs-bridge/ page slug to this setting, clear all saved cache and update your plugin.
    To speed up your WHMCS Bridge, please enable caching within the WHMCS Bridge Settings page (Pro Plugin).
1 answer to this question
Answer this question...
