Display Products on Homepage
Hello, I am a newbie here, I am developing a custom template for my company based on the Latest Twenty-One system theme.
The theme works well but I have a problem trying to create a hook that queries products and return them to the $myproducts variable using the
ClientAreaPage hook but I have failed to get my hook running, on checking Activity log I see Hook Debug: No Hook functions defined for ClientAreaPage.
<?php
use WHMCS\Database\Capsule;
function homepage_products_hook($vars)
	$products = Capsule::table('tblproducts')
		->join('tblpricing', 'tblproducts.id', '=', 'tblpricing.relid')
		->where('tblpricing.type', 'product')
		->where('tblproducts.hidden','0')
		->where('tblproducts.gid','1')
		->select('tblproducts.id','tblproducts.name','tblproducts.description','tblpricing.monthly')
		->orderBy('tblproducts.order')
		->groupBy('tblproducts.id')
		->get();
	$results = json_decode(json_encode($products), true);
	return array("myproducts" => $results);
add_hook("ClientAreaPage", 1, "homepage_products_hook");
I have created that file in `includes/hooks/homepage_products_hook.php`.
Is there anything am doing wrong? I need your help.
