s77rt Posted October 21, 2022 Share Posted October 21, 2022 (edited) RDPCloud RDP Control Panel Simple & Innovative Designed to simplify the process of RDP Control for hosting providers and users Features Portable RDPCloud is portable, works out of the box, and requires zero configuration Secure by Design RDPCloud is built with security in mind, all network requests are encrypted, and every core functionality is hardened and designed based on the principles of security by design Easy to Integrate RDPCloud comes with free plugins for easy integration with extensible software, such as WHMCS User Management RDPCloud lets you manage users (create, modify, delete, etc.) and their local groups (add user to local group, remove user from local group, etc.) Quota Management RDPCloud lets you manage disk quotas (enable disk quota, set default disk quota, disable disk quota, etc.) and disk quota entries (set disk quota entry, delete disk quota entry, etc.) WinAPI Support RDPCloud can be extended to support any Windows functionality exposed via WinAPI Client/Server Approach RDPCloud, unlike other solutions, adopts the client/server approach, giving you more flexibility and control Developer Friendly RDPCloud, being developer friendly, uses Protocol Buffers, making it easier to communicate with RDPCloud Server in any supported language Cross-Platform RDPCloud Client is cross-platform and runs on Linux, Windows, and macOS. RDPCloud Server runs on Windows only Download Standard Version $99/per server Ideal for personal use and SMBs Get a 30-Days Free Trial Contact via Telegram DEMO Edited October 21, 2022 by s77rt 0 Quote Link to comment Share on other sites More sharing options...
s77rt Posted October 25, 2022 Author Share Posted October 25, 2022 Another DEMO (WHMCS Integration) 0 Quote Link to comment Share on other sites More sharing options...
