Problem in WHMCS
pasargad
Hi all!
I'm using WHMCS 8.4.1
in error_log show:
[13-Apr-2022 14:29:32 UTC] PHP Warning:  function_exists() expects exactly 2 parameters, 1 given in /home/userhost/public_html/whmcspath/init.php on line 0
[13-Apr-2022 14:29:32 UTC] PHP Warning:  is_callable() expects exactly 2 parameters, 1 given in /home/userhost/public_html/whmcspath/vendor/whmcs/whmcs-foundation/lib/Utility/Error/Run.php on line 0
[13-Apr-2022 14:29:32 UTC] [WHMCS Application] ERROR: TypeError: Return value of WHMCS\Hook\Manager::toString() must be of the type string, null returned in /home/userhost/public_html/whmcspath/vendor/whmcs/whmcs-foundation/lib/Hook/Manager.php:0 Stack trace: #0 /home/userhost/public_html/whmcspath/vendor/whmcs/whmcs-foundation/lib/Hook/Manager.php(0): WHMCS\Hook\Manager->toString(Object(Closure))
#1 /home/userhost/public_html/whmcspath/vendor/whmcs/whmcs-foundation/lib/Hook/PublicRegistry.php(0): WHMCS\Hook\Manager->add('ClientAreaSideb...', -1, Object(Closure), '')
#2 /home/userhost/public_html/whmcspath/vendor/illuminate/support/Facades/Facade.php(261): WHMCS\Hook\PublicRegistry->add('ClientAreaSideb...', -1, Object(Closure), '')
#3 /home/userhost/public_html/whmcspath/includes/functions.php(0): Illuminate\Support\Facades\Facade::__callStatic('add', Array)
#4 /home/userhost/public_html/whmcspath/vendor/whmcs/whmcs-foundation/lib/MarketConnect/Promotion.php(0): add_hook('ClientAreaSideb...', -1, Object(Closure))
#5 /home/userhost/public_html/whmcspath/vendor/whmcs/whmcs-foundation/lib/Hook/Manager.php(0): WHMCS\MarketConnect\Promotion::initHooks()
#6 /home/userhost/public_html/whmcspath/vendor/illuminate/support/Facades/Facade.php(261): WHMCS\Hook\Manager->boot()
#7 /home/userhost/public_html/whmcspath/init.php(0): Illuminate\Support\Facades\Facade::__callStatic('boot', Array)
#8 /home/userhost/public_html/whmcspath/AdminsPanel/index.php(0): unknown()
#9 {main} {"exception":"[object] (TypeError(code: 0): Return value of WHMCS\\Hook\\Manager::toString() must be of the type string, null returned at /home/userhost/public_html/whmcspath/vendor/whmcs/whmcs-foundation/lib/Hook/Manager.php:0)"} []
what is the problem?
thank you
  • 3 weeks later...
