Help with an IF statement
I want to add a little bit of text on the 'addons' page of clientareadomaindetails.tpl if privacy protection is enabled.
This is what I have but the IF variable is not correct. I've tried several variations. I also added {debug} to the top of the file (using Twenty-One theme) and it doesn't show the variables like SIX does. Edit: {debug} is working on the Twenty-One template.
I am trying to write this:
{if $isprivacyon eq "true"}
<p>DISPLAY SOME TEXT</p>
{/if}
This is wrong: $isprivacyon eq "true"
Does anyone know the right variable and mind helping me out? Thanks!
I use the LCDRM module from Resellerclub-Mods so that may mean the variable is different from original WHMCS smarty variable?
Edited by evolve hosting
