rbro Posted January 3, 2008 Share Posted January 3, 2008 I'm still mucking about trying to get the Google analytics conversion goals to work correctly, but then I also see there is a separate conversion tracking code snippet that is part of Adwords. I've gone in to admin and changed the order process so it no longer redirects to the invoice on checkout (per Matt's suggestion) and I tried adding the adwords conversion code to the bottom of order-complete.tpl. But when I place an order, I'm redirected to a blank page at https://mydomain.com/client/order.php?step=checkout. I removed the code and ran another test order and it worked fine. Any ideas? 0 Quote Link to comment Share on other sites More sharing options...
