Enable SSO on a laravel project and integrate it with WHMCS & WordPress
I have a laravel project on which I want to implement SSO as IDP and use WHMCS and WordPress as SP. After searching I found SAML as a solution but how to use it in laravel and integrate it into WHMCS and Wordpress?.
And through a blog, I came to know that WHMCS does not support SAML then what I can use in that case?.
My main objective is that when I login in my application, Whmcs, and WordPress should also get logged in using SSO.
