josef214 Posted September 2, 2019 Share Posted September 2, 2019 Problem of REcaptcha Hello I'm new to WHMCS, I've had a problem since this morning and I can't fix it anymore, how can I disable it, to get into dashboard? Please help! Thank you. 0 Quote Link to comment Share on other sites More sharing options...
KyleGHN Posted September 9, 2019 Share Posted September 9, 2019 Hello there, Do you have access to the database via cPanel or whatever platform you are using? If so, search for the table "tblconfiguration," and inside that table search in the setting column for "CaptchaForms." Open that up and update the setting (I always recommend backing up your database before performing table changes): {"checkoutCompletion":false,"domainChecker":true,"registration":true,"contactUs":true,"submitTicket":true,"login":true} To- {"checkoutCompletion":false,"domainChecker":false,"registration":false,"contactUs":false,"submitTicket":true,"login":false} Hopefully this helps! Best Regards, Kyle 0 Quote Link to comment Share on other sites More sharing options...
