Yubico Two-Factor Deactivated DUO Activated Issue
bayden10
We had Yubico enabled and not all admins had access to Yubico so we deactivated Yubico and then enabled DUO as Active. When logging in to Admin Panel set to "  Force Administrator Users to enable Two Factor Authentication on Next Login " but the Two Factor resorts to  TOTP with Google Authenticator which was disabled and Deactivated. DUO Two Factor never displays.
Jim
