Help with converting SQL query to Laravel
ezyweb
G'day folks!
I'm hoping someone can help me with the correct Laravel structure for the following query ...
UPDATE radreply SET value=(SELECT ip FROM radip WHERE allocated='$username') WHERE value='' AND username='$username'
Your help will be greatly appreciated.
Kerry
First, check this and this
Then, the easy way:
$ip = Capsule::table('radip')->where("allocated", $username )->value();
Capsule::table('radreply')
    ->where("value", '')
    ->where("username", $username)
    ->update(['value' => $ip]);
Start from there before going into subselect queries
Edited by egrueda
