berkarg Posted September 12, 2018 Share Posted September 12, 2018 Hello, I want to show a URL address in Whmcs like a different url. I want to configure some url addresses as I want. For example, the current url is: http://whmcs.community/test-file I want this url to : http://whmcs.community/test-file/yes/community/yea/testing My system Information : WHMCS Version : 7.4.2 PHP Version : 5.6.37 My .htaccess : RewriteRule ^test-file/yes/community/yea/testing test-file.php [NC,L] My test-file.php : <?php define("CLIENTAREA",true); //define("FORCESSL",true); // Uncomment to force the page to use https:// require("init.php"); $ca = new WHMCS_ClientArea(); $ca->setPageTitle("Test File"); $ca->addToBreadCrumb('index.php',$whmcs->get_lang('globalsystemname')); $ca->addToBreadCrumb('test-file.php','Test File'); $ca->initPage(); // $ca->requireLogin(); // Uncomment this line to require a login to access this page # To assign variables to the template system use the following syntax. # These can then be referenced using {$variablename} in the template. $ca->assign('pagelayout', nonwhmcs); $ca->assign('pagetype', planpage); # Check login status if ($ca->isLoggedIn()) { # User is logged in - put any code you like here # Here's an example to get the currently logged in clients first name $result = mysql_query("SELECT firstname FROM tblclients WHERE id=".$ca->getUserID()); $data = mysql_fetch_array($result); $clientname = $data[0]; $ca->assign('clientname', $clientname); } else { # User is not logged in } # Define the template filename to be used without the .tpl extension $ca->setTemplate('test-file'); $ca->output(); ?> My test-file.tpl : <!-- Package Start --> <div class="col-sm-6 col-md-4 margin-top-30"> <div class="panel panel-info relative"> <!--<div class="ribbon ribbon-small text-white"> <div class="ribbon-content bg_primary text-uppercase text_white"> OFFER </div> </div>--> <div class="panel-heading"> <h3 class="text-center"> <script language="javascript" src="feeds/productsinfo.php?pid=452&get=name"></script> </h3> <h2> <i class="fa fa-linux"> </i> </h2> </div> <div class="panel-body text-center"> <div class="price-cercle"> <!-- <h6 class="through-line common-price">$ xxxx</h6> --> <h4> <script language="javascript" src="feeds/productsinfo.php?pid=452&get=price&billingcycle=monthly¤cy=1"></script> </h4> <span class="per">AYLIK</span> </div> </div> <ul class="text-center"> <script language="javascript" src="feeds/productsinfo.php?pid=452&get=description"></script> </ul> <div class="panel-footer"> <a class="btn btn-new btn-lg" href="cart.php?a=add&pid=452">SATIN AL</a> </div> </div> </div> <!-- Package End --> As you can see in the above file, whmcs does not capture product information when I make .htaccess redirects. When the url is changed with .htaccess, no information is returned. Codes that do not work with urls: <script language="javascript" src="feeds/productsinfo.php?pid=452&get=name"></script> <script language="javascript" src="feeds/productsinfo.php?pid=452&get=price&billingcycle=monthly¤cy=1"></script> <script language="javascript" src="feeds/productsinfo.php?pid=452&get=description"></script> Why is Whmcs unable to capture product information in the artificial URL made with .htaccess? Sorry, for my bad english, i using google translate. Thanks for all helping i waiting you for fix this issue. 0 Quote Link to comment Share on other sites More sharing options...
