Xenica 3.1 - Citrix XenServer managment and autoprovisionning module for WHMCS
Hi All
We are please to announce the public release of Xenica 3.1.
Xenica is whmcs module for provisioning and managing Citrix xenservers and XCP-NG
Xenica got a lot of new features and a lot of UI/UX improvements over the past release.
The current feature list are:
General features
Easy VM Provision with wide range of OSs (CentOs, Debian, ubuntu and windows server)
Full VM control
Full VM info
Support latest XenServer Version
Support latest WHMCS version
Support PHP7
auto assign ip addresses on new orders
Support VM multiple IPs
Bandwidth Billing
Support Debug mode and whmcs module logging
useful and clear wiki documentation
Full utilization of XenAPI which results in :
More Security : no extra services running on Xen machine
Lightweight on the server
More stability : stability of the module is the same as XenApi stability
Clients Panel :
Show VM info (Host,IP, Password, Registration Date, Bandwidth Usage, etc.. )
Detect VM current power state (Running, Halted, Paused)
Basic VM Control (Boot, Shutdown, Reboot)
VM Change Root Password (clients can reset their VMs password)
VM ReInstall (can select OS from allowed templates list)
VM SnapShots (list, create, delete)
VM Console (noVNC console page for Linux/Windows, still work even if SSH is off)
VM Graph/Stats (statistics graph for HD,Net,CPUs,RAM Usage)
VM mount CD (can mount an ISO file from Server Storage Repository)
Admins Panel :
Product/service Panel:
Login as user (user side panel)
Show VM Full info (Host,IP, Password, Bandwidth Usage,Home Server, Resources etc.. )
VM Full control (Crate, suspend, Terminate, reboot, pause, shutdown,reset bandwidth )
VM reinstall
VM change root password
VM Console
VM change CPUs
VM change RAM size
VM change Disk size
VM run boot commands (run commands as root on the next vm startup)
VM SnapShots
VM Mount CD
VM change Host name
show VM Graph/Stats
show full vm record data (Xen API)
Show last vm 5 commands log
Xenica VMs List
List Xenica VMs Details from WHMCS db (name, user, regdate, domain, IP, server, status , notes ..)
search for any vm depends on any field
filter vms by status
Xenica Servers List
List Xen Servers from WHMCS db
show Server VMs count and list server VMs
list server os templates
List Server VMs that is not added to whmcs DB
List whmcs VMs that is not exist on Xen Server
Xenica Users List
List Xenica Users from WHMCS db
Search for any user
filter users by VM status
List User Active VMs
Xenica IP Manger
List and Add/modify IPs
Search IPs
separate IPs in groups (by Datacenter/NOC)
show available/assigned IPs
show allocated vm for each IP
List All IPs for certain user
Add Range of IPs
Others:
client panel pages are templates that can be modified as files if needed
client panel support multilingual (translations can be added )
For more information about the module and to check its wiki please visit the following links
https://xenmodule.com/
https://wiki.xenmodule.com/
we are pleased to inform you that we have dedicated team working on the module which will improve the support process greatly.
Also in order to make the trial process much faster we decided to offer the module as linux app (Virtual machine on xenserver with the module already installed and configured) all you need is to get free license from us for 1 month and get a whmcs dev license (free, you have to open a ticket with whmcs and they will give you the license)
That way you don’t have to go through the steps to install the module if you just want to test / trial it
As usual we have 1 Month trial free using this promo code XENICATRIAL
One important thing that we have changed is the licensing of the module . as we decided to no longer license the module per server basis and instead license the module per whmcs instance basis .
So the module now can be used with unlimited xenservers as long as it is being used from one whmcs.
you can download the module from the client area at this url
https://servarica.com/clients/cart.php?a=add&pid=120
and install instructions are at the wiki
https://wiki.xenmodule.com/doku.php?id=xenica_install_instructions
if you have any questions please contact us at support@servarica.com
Thanks
