ShoppingCartValidateCheckout hook help validating tld
molcomp
Hello
I appreciate if anyone can help me in fixing the hook.  I know the issue but I dont know how to resolve it.  The problem is with the tld variable  that I am trying to validate for the domain inside the cart. The variable I am using is $vars['tlds']  and it is not correct.
Thanks
Alex
<?php
add_hook('ShoppingCartValidateCheckout', 1, function ($vars)
    if ($vars['registranttype'] == 'Personal' AND $vars['tlds'] == '.com' )
        {return  'Private person can register only .mk subdomains'  ;    }
        return  'You are allowed to register the domain';
