How to execute custom module after Cpanel Module in products & services
Hi, I want to run/execute an entire custom module after execution of Cpanel Module. I'm not able to figure it out, how I may execute module code in AfterModuleCreate hook as my custom module has its own subdirectory and additional required files. My module is independently functioning in the WHMCS user interface. This is how my code looks:
<?php
if (!defined("WHMCS"))
    die("This file cannot be accessed directly");
define("SiteBuilder", "1.0.0");
function sitebuilder_config() {
    return $configarray;
function sitebuilder_activate() {
function sitebuilder_deactivate() {
function sitebuilder_upgrade($vars) {
function sitebuilder_output($vars) {
    require_once 'sitebuilder_library.php';
    require_once 'admin/header.php';
