Danse Posted October 24, 2017 Share Posted October 24, 2017 HI, i have following Problem: We use WHMCS Plesk provisioning and or PleskExtend from ModulesGarden (which somehow and i really don't understand why, is build on top off WHMCS Plesk Module) and we have a Problem: 1. New Customer orders a Webspace & Domain. The Webspace gets provisioned first - then the Domain Details should be send over to external Registrar (Domain Module we already have). 2. Which IP will be used for the Domain Records? We want to send over the right ip from our Plesk Server - this is my Question: Which field out from Database to you use? Does someone has some Domain Module template for sending over the IPv4 for Plesk to Domain Registrar? While the Domain Registrar Module atm pulls Data out from "tblhosting > dedicatedip" which usually filled in by the Provisionig Module. My Partner uses this for long time, but my tblhosting dedicated and assignedip Columns (in Database) are empty. Any Ideas? 0 Quote Link to comment Share on other sites More sharing options...
