Using wbTeamPro Project Management Module
Has anyone experience with wbTeamPro Project Management add on? I'm trying to get to grips with the structure of Projects and how to use it as it's different to other tools I've used before.
When you create a new project an action/milestone is auto created inside the project. My question is how to create new top-level actions? It only appears to be possible to add child actions underneath the auto created milestone? It doesn't seem possible to add additional top-level actions/milestones from what I can see?
  • 3 weeks later...
