MatteoWN Posted June 11, 2017 Share Posted June 11, 2017 Hi everyone, We've been developing our module for our own VPS Control panel, but I having a little bit of issues (To WHMCS guys, please make a more detailed documentation!) Here's the situation: Configuration Function: function WNCloud_ConfigOptions() { return array ( // Choose Node button "node" => array( "FriendlyName" => "Node", "Type" => "dropdown", "Options" => "nodo-02", "Description" => "Decide on which node create the VPS", "Default" => "nodo-02", ), // Choose Template button "template" => array( "FriendlyName" => "Server Template", "Type" => "dropdown", "Options" => getTemplates(), "Description" => "Define which template should be installed by default", "Default" => "800", ), ); } Crate Account Function: function WNCloud_CreateAccount(array $params) { global $db; try { $oid = incrementalHash(); $status = 'SETUP_WAIT'; $p = '0'; $sql = $db->prepare('INSERT INTO daemon (order_id, template_id, user, status, pass, root_pw) VALUES (:oid, :t, :user, :status, :pass, :pw)'); $sql->bindParam(':oid', $oid); $sql->bindParam(':t', $params['configoption2']); $sql->bindParam(':user', $params['clientsdetails']['email']); $sql->bindParam(':status', $status); $sql->bindParam(':pass', $p); $sql->bindParam(':pw', $params['customfields']['password']); $sql->execute(); } catch (Exception $e) { logModuleCall( 'WNCloud', __FUNCTION__, $params, $e->getMessage(), $e->getTraceAsString() ); return $e->getMessage(); } return 'success'; } Other functions just like incrementalHash() and getTemplates() are working just fine! but the creation function just loops over and over when I click on the "Create" button from within WHMCS. Am I using the $params array wrong? Regards 0 Quote Link to comment Share on other sites More sharing options...
