pointaction Posted May 4, 2017 Share Posted May 4, 2017 This is my problem that I am having. With the Integrator has closed their doors and they only gave up to January 1, 2018 for the current license to work until the end of this year. So I am running Rockettheme Jooomla 3.7 I have put WHMCS on the main domain as a sub folder. I have to use Joomla's Wrapper » Iframe Wrapper which it says WHMCS has to be on the same domain to the main website for auto height to work. I did some testing and auto height does not work but I can specify exact height of each page listed in the menus of WHMCS. Plus I can place those pages in Joomla Menus of the website. I would need to use hooks or edit your order form template whatever is the easiest to do. Back in versions 4 and 5 I had no problem 6 and 7 it is little tougher for me. I am not a high-end programmer but I do know how to make some modifications to code to a certain degree. With this in mind I would like to how to hide just the side bar menu so that they do not show up. So if any be kind of to help me with this I would be very grateful. Thank you 0 Quote Link to comment Share on other sites More sharing options...
pointaction Posted May 4, 2017 Author Share Posted May 4, 2017 I figured out to change things without using hooks but after login to client area on the home page I want to remove the Shortcuts Box. I just cannot find where it is at. Does anyone know where this is at? 0 Quote Link to comment Share on other sites More sharing options...
pointaction Posted May 4, 2017 Author Share Posted May 4, 2017 I figured out to change things without using hooks but after login to client area on the home page I want to remove the Shortcuts Box. I just cannot find where it is at. Does anyone know where this is at? I found where it is at. 0 Quote Link to comment Share on other sites More sharing options...
