lindem Posted November 7, 2007 Share Posted November 7, 2007 Hello, Every time some one sends me an email, they receive this message from the server: This message was created automatically by mail delivery software. A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed: pipe to | php -q /home/*****/public_html/clients/pipe/pipe.php generated by support@********.com The following text was generated during the delivery attempt: ------ pipe to | php -q /home/*****/public_html/clients/pipe/pipe.php generated by suporte@hostbrasileiro.com ------ PHP Warning: PHP Startup: pdo_mysql: Unable to initialize module Module compiled with module API=20060613, debug=0, thread-safety=0 PHP compiled with module API=20050922, debug=0, thread-safety=0 These options need to match in Unknown on line 0 No log handling enabled - turning on stderr logging read_config_store open failure on /var/net-snmp/snmpapp.conf read_config_store open failure on /var/net-snmp/snmpapp.conf read_config_store open failure on /var/net-snmp/snmpapp.conf Can anyone help me? Regards 0 Quote Link to comment Share on other sites More sharing options...
methos Posted November 11, 2007 Share Posted November 11, 2007 this is not a whmcs issue, but the pdo_mysql module is installed against the wrong version of php. you can do a search on the web against "pdo_mysql: Unable to initialize module" to see some explanations of this, or simply pass it on to your server admin to fix it. 0 Quote Link to comment Share on other sites More sharing options...
DeanClinton Posted November 11, 2007 Share Posted November 11, 2007 I also had this error... I recompiled PHP without snmp 0 Quote Link to comment Share on other sites More sharing options...
