suprahost Posted October 29, 2007 Share Posted October 29, 2007 Hello  all current accounts with package "Linux Basic" can't be imported on WHMcs (using WHM IMPORT SCRIPT) because the Package that doesn't exist in WHMCS.  However I created "Linux Basic" in WHMcs too !  What is the problem please ?  Thanks 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted October 30, 2007 Author Share Posted October 30, 2007 I am the only to have this problem ? 0 Quote Link to comment Share on other sites More sharing options...
Retired Forum Member WHMCS Joe Posted October 31, 2007 Retired Forum Member Share Posted October 31, 2007 Please submit a ticket and we will take a look at this for you. 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted November 2, 2007 Author Share Posted November 2, 2007 please can your replicate the problem on your server ? For our policies we do not assign root. Â Simply create a package with a space inside , for example "linux basic". Try it , as can you see the import does not work. Â Please can you fix it , or do I need to rename all my plans without a " " inside ? Â Thanks 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted November 2, 2007 WHMCS CEO Share Posted November 2, 2007 Just tested it and confirmed it works fine with a space so the problem will be your configuration. Refer to the guide in the manual on how to use this feature. Â Matt 0 Quote Link to comment Share on other sites More sharing options...
suprahost Posted November 2, 2007 Author Share Posted November 2, 2007 my fault sorry , I confused "product name" with "package name". 0 Quote Link to comment Share on other sites More sharing options...
