Recommended Cron Jobs and Task Control Using Flags
EIYEI Digital
Cron discussions are so scattered that I thought this thread will help a lot of people (including me) to set cron jobs properly and share experiences doing so...
First, for all non-tech savvy users, a basic (very basic) view about cron jobs:
A Cron is a system (server) daemon (program) used to execute desired tasks (in the background) at designated times. It has 6 well defined parts as you can see:
01 04 1 1 1 /home/user/somedirectory/somecommand
Where the first 5 groups of digits, tell the cron when to execute the task or command...:
In the same order as the example above, from left to right, each group of digits tell:
minute (0-59 /* every minute), hour (0-23, 0 = midnight /* every hour), day (1-31 /* every day), month (1-12 /* every month), weekday (0-6, 0 = Sunday /* every weekday), command
So, in the example above somecommand will run every monday of january dated 1st at 4:01am
According to the WHMCS documentation you should run daily this: (http://docs.whmcs.com/Crons)
php -q /home/user/whmcs/crons/cron.php
So, in your cPanel > Cron Jobs section, you will have something like:
15 7 * * * php -q /home/user/whmcs/crons/cron.php > /dev/null 2>&1
Let's see that part by part:
15 7 * * * means that it will run on the minute 15, of the hour 7, every day, every month every weekday, in plain english, every day at 7:15am (server time).
It will execute the command php -q /home/user/whmcs/crons/cron.php
php -q means it will use php and will do it quietly (-q)
And the last bit > /dev/null 2>&1, tells the cron not to show/generate any output of the command, so you don't receive endless emails with the detail of the execution.
Done with the basic technical part... So for the practical day-to-day implementation..
Cron Flags (task control) (http://docs.whmcs.com/Cron_Tasks)
I've been struggling to run cron.php with the flag skip_backups, every time it runs, the backup gets generated.
That is php -q /home/user/whmcs/crons/cron.php skip_backups
Why would I like to do that? Well, I want to run the main cron once a day (or do you recommend something else) and backup my database twice a day...
I have seen a couple of posts where, for example, we want to skip suspensions during weekends, so you can deal with them during office hours mon-fri. Makes sense!
So, you would run, for your daily cron task something like:
daily:
15 7 * * * php -q /home/user/whmcs/crons/cron.php skip_suspensions
and for your suspensions alone:
suspensions:
15 8 * * 1-5 php -q /home/user/whmcs/crons/cron.php do_suspensions
Also, someone suggested to skip invoicing during weekends and do it the next working day (monday), so it would be something like (following the previous example):
daily:
15 7 * * * php -q /home/user/whmcs/crons/cron.php skip_suspensions skip_invoices
and for your suspensions+invoicing alone:
suspensions+invoicing:
15 8 * * 1-5 php -q /home/user/whmcs/crons/cron.php do_suspensions do_invoices
So, here my requests... if you'd like to help, leave your recommended cron tasks, everything from your experience will for sure help someone else...
And, why is my skip_backups flag not working? I checked the documentation and couldn't find any troubleshooting information on this... http://docs.whmcs.com/Cron_Job_Issues
