hsnuwaninfo Posted December 17, 2015 Share Posted December 17, 2015 I included the our payment gateway providers iframe in merchantgateway.php. And I capture the token inside callback according to the WHMCS payment gateway sample code. Initial payment is working and a token is returned. I tried to test recurring payment by changing the next due date to yesterday date and run the cron. But the automatic recurring payment does not happen. I tried to implement whmcs hook on callback to do the recurring payment. Am going the right direction? I would be much grateful to you if could help on this My code is given below payment module <?php function paybank_config() { $configarray = array( "FriendlyName" => array("Type" => "System", "Value" => "XXXX Bank"), ); return $configarray; } function paybank_link($params) { $client_hash = 'xxxxxxxxxxxxxxxxxxxxxxxx'; $code = '<iframe id="showEntry" width="100%" height="350" src="https://[payment-gateway-url]?clientIdHash='.$client_hash.'&paymentAmount='.$params['amount'].'"></iframe>'; $_SESSION['paybank_amount'] = $params['amount']; $_SESSION['paybank_invoiceid'] = $params['invoiceid']; return $code; } function paybank_refund($params) { # Gateway Specific Variables $gatewayusername = $params['username']; $gatewaytestmode = $params['testmode']; # Invoice Variables $transid = $params['transid']; # Transaction ID of Original Payment $amount = $params['amount']; # Format: ##.## $currency = $params['currency']; # Currency Code # Client Variables $firstname = $params['clientdetails']['firstname']; $lastname = $params['clientdetails']['lastname']; $email = $params['clientdetails']['email']; $address1 = $params['clientdetails']['address1']; $address2 = $params['clientdetails']['address2']; $city = $params['clientdetails']['city']; $state = $params['clientdetails']['state']; $postcode = $params['clientdetails']['postcode']; $country = $params['clientdetails']['country']; $phone = $params['clientdetails']['phonenumber']; # Card Details $cardtype = $params['cardtype']; $cardnumber = $params['cardnum']; $cardexpiry = $params['cardexp']; # Format: MMYY $cardstart = $params['cardstart']; # Format: MMYY $cardissuenum = $params['cardissuenum']; # Perform Refund Here & Generate $results Array, eg: $results = array(); $results["status"] = "success"; $results["transid"] = "12345"; # Return Results if ($results["status"] == "success") { return array("status" => "success", "transid" => $results["transid"], "rawdata" => $results); } elseif ($gatewayresult == "declined") { return array("status" => "declined", "rawdata" => $results); } else { return array("status" => "error", "rawdata" => $results); } } ?> callback file <?php # Required File Includes include("../../../init.php"); include("../../../includes/functions.php"); include("../../../includes/gatewayfunctions.php"); include("../../../includes/invoicefunctions.php"); $gatewaymodule = "paybank"; # Enter your gateway module name here replacing template $GATEWAY = getGatewayVariables($gatewaymodule); if (!$GATEWAY["type"]) die("Module Not Activated"); //echo $_SESSION['paybank_amount'];die; //echo $_POST["amount"]. '%%%%';die; $table = "tblinvoices"; $fields = "userid"; $where = array("id"=>$invoiceid); $result = select_query($table,$fields,$where); $data = mysql_fetch_array($result); $sql = "SELECT userid FROM tblinvoices WHERE id = {$invoiceid}"; $result = mysql_query($sql); $row = mysql_fetch_assoc($result); update_query( "tblclients", array( "cardnum" => "", "gatewayid" => $req_response->token ), array("id" => $data['userid']) ); header('Location:http://express-web.negete.net/order/successful/'.$req_response->txnReference.''); } else { echo "Invalid Invoice Number"; } } else { echo ("The response have been altered along the way. Please contact us immediately"); } 0 Quote Link to comment Share on other sites More sharing options...
