superman15 Posted September 8, 2015 Share Posted September 8, 2015 Right i have created the following files WHMCS_DIR/test.php WHMCS_DIR/template/demo/test.tpl I wanted to remove the breadcrum and the page title from the top of the page on this custom page. So i found "pageheader.tpl" in "WHMCS_DIR/templates/demo/includes/pageheader.tpl" and found the following code <div class="header-lined"> <h1>{$title}{if $desc} <small>{$desc}</small>{/if}</h1> {if $showbreadcrumb}{include file="$template/includes/breadcrumb.tpl"}{/if} </div> and i changed it to the following {if $filename!='test'} <div class="header-lined"> <h1>{$title}{if $desc} <small>{$desc}</small>{/if}</h1> {if $showbreadcrumb}{include file="$template/includes/breadcrumb.tpl"}{/if} </div> {/if} This has removed what i need from the page, but the issue is it only removes what i want it too from test.php i would like to be able to use the instance above on more than one page. I was wondering if there was some code i was missing to make this work over multiple pages. Any help would be greatly apprechiated Many thanks 0 Quote Link to comment Share on other sites More sharing options...
superman15 Posted September 8, 2015 Author Share Posted September 8, 2015 {if $filename!='test' && $filename!='test2'} <div class="header-lined"> <h1>{$title}{if $desc} <small>{$desc}</small>{/if}</h1> {if $showbreadcrumb}{include file="$template/includes/breadcrumb.tpl"}{/if} </div> {/if} - - - Updated - - - I worked it out here is how i did it {if $filename!='test' && $filename!='test2'} <div class="header-lined"> <h1>{$title}{if $desc} <small>{$desc}</small>{/if}</h1> {if $showbreadcrumb}{include file="$template/includes/breadcrumb.tpl"}{/if} </div> {/if} 0 Quote Link to comment Share on other sites More sharing options...
