Problem with "Login To WHM" button in WHMCS 6
mohseni
when i am using "Login To WHM" button in admin area , URL redirect to secure Contention with original server hostname address
For Example :
https://server12.orginalhostname.com:2087/*****
Now , I edit server Configuration in server list and disable "secure"
I click on the "Login To WHM button again and recived this error:
cPanel API Unreachable: Connection Error: Failed to connect to x.x.x.x port 2086: Connection timed out(7)
While in previous versions is not problem
