Menu Hooks Not Working for Project Management Add-On Menu Items
ignisium
I've come across an apparent bug with the menu hook system. In re-arranging the menu, I make a hook to change the list order for the Project Management Add-On menu item "My Projects." I've attached the code below.
All of my other hooks for the menu work fine, but this does nothing. I've tried other hooks such as changing the name of the menu item and those fail as well.
My best guess is that PM is being loaded after the menu hooks are loaded, which is why the hooks fail to take effect for the PM menu items. Is there a workaround for this?
add_hook('ClientAreaPrimaryNavbar', 1, function (MenuItem $primaryNavbar)
   $navItem = $primaryNavbar->getChild('pm-addon-overview');
   if (is_null($navItem)) {
       return;
   $navItem->setOrder(4);
