Product downloads Issue
Nathanael
Steps to reproduce:
1- Edit any product.
2- Click "other" tab.
3- Select a category and try to upload a file.
Fatal error: Uncaught exception 'Illuminate\Database\QueryException' with message 'SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'category' cannot be null (SQL: insert into `tbldownloads` (`category`, `type`, `title`, `description`, `location`, `clientsonly`, `productdownload`, `updated_at`, `created_at`) values (, zip, test, test, wmleaseweb312a.zip, 1, 1, 2015-07-26 13:25:40, 2015-07-26 13:25:40)) (SQL: insert into `tbldownloads` (`category`, `type`, `title`, `description`, `location`, `clientsonly`, `productdownload`, `updated_at`, `created_at`) values (, zip, test, test, wmleaseweb312a.zip, 1, 1, 2015-07-26 13:25:40, 2015-07-26 13:25:40))' in /home/nathan/webs/whmcsmod-panel/includes/classes/WHMCS/Terminus.php on line 0
( ! ) Illuminate\Database\QueryException: SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'category' cannot be null (SQL: insert into `tbldownloads` (`category`, `type`, `title`, `description`, `location`, `clientsonly`, `productdownload`, `updated_at`, `created_at`) values (, zip, test, test, wmleaseweb312a.zip, 1, 1, 2015-07-26 13:25:40, 2015-07-26 13:25:40)) (SQL: insert into `tbldownloads` (`category`, `type`, `title`, `description`, `location`, `clientsonly`, `productdownload`, `updated_at`, `created_at`) values (, zip, test, test, wmleaseweb312a.zip, 1, 1, 2015-07-26 13:25:40, 2015-07-26 13:25:40)) in /home/nathan/webs/whmcsmod-panel/includes/classes/WHMCS/Terminus.php on line 0
Seems the issue is that the category is not set although i selected it previously.
