Problem with Cron WHMCS 6
hostttu
Since I had updated to WHMCS 6 the Cron is not working I have received this email message intead the Cron Daemon report:
<b>Fatal error</b>: <br>The file <b>/home/******/public_html/clientes/crons/cron.php</b> was encoded with the PHP 5.3 ionCube Encoder and requires PHP 5.3 to be installed. in <b>Unknown</b> on line <b>0</b><br />
Any ideas? Somebody have the same issue?
Thanks.
I had this exact same issue. I fixed it by logging into cPanel, going into cron jobs and I noticed that the cron was programmed in PHP 5.2.
Find the cron in your list and change the first part of the command to: /opt/php53/bin/php-cgi -q
  • 2 months later...
