meudayg1 Posted November 21, 2014 Share Posted November 21, 2014 Hi All, I'm new to this forum and very less exposed to coding stuff. Please help me on below issue. We are using below code for license validations and due to some technical challenges our server is going down which in turn effecting our users I want to make few changes like Even if our server is down for some time it should not impact our users(their site should not be down) or Temporarily disable license validations or user site should not check for license (week or month). function check_license($licensekey, $localkey = '') { $whmcsurl = 'http://abc.com/license'; $licensing_secret_key = 'xyzabd123*******'; $check_token = time( ) . md5( mt_rand( 1000000000, 9999999999 ) . $licensekey ); date( 'Ymd' ); $checkdate = ; $usersip = (isset( $_SERVER['SERVER_ADDR'] ) ? $_SERVER['SERVER_ADDR'] : $_SERVER['LOCAL_ADDR']); $localkeydays = 21; $allowcheckfaildays = 16; $localkeyvalid = false; if ($localkey) {str_replace( '', '', $localkey ); $localkey = ; substr( $localkey, 0, strlen( $localkey ) - 32 ); $localdata = ; substr( $localkey, strlen( $localkey ) - 32 ); $md5hash = ; if ($md5hash == md5( $localdata . $licensing_secret_key )) { strrev( $localdata ); $localdata = ; substr( $localdata, 0, 32 ); $md5hash = ; substr( $localdata, 32 ); $localdata = ; base64_decode( $localdata ); $localdata = ; unserialize( $localdata ); $localkeyresults = ; $localkeyresults['checkdate']; $originalcheckdate = ; if ($md5hash == md5( $originalcheckdate . $licensing_secret_key )) { date( 'Ymd', mktime( 0, 0, 0, date( 'm' ), date( 'd' ) - $localkeydays, date( 'Y' ) ) ); $localexpiry = ; if ($localexpiry < $originalcheckdate) {$localkeyvalid = true; $localkeyresults; $results = ; explode( ',', $results['validdomain'] ); $validdomains = ; if (!in_array( $_SERVER['SERVER_NAME'], $validdomains )) { $localkeyvalid = false; $localkeyresults['status'] = 'Invalid'; $results = array( ); } explode( ',', $results['validip'] ); $validips = ; if (!in_array( $usersip, $validips )) { $localkeyvalid = false; $localkeyresults['status'] = 'Invalid'; $results = array( ); } if ($results['validdirectory'] != dirname( __FILE__ )) { $localkeyvalid = false; $localkeyresults['status'] = 'Invalid'; $results = array( ); } } } } } if (!$localkeyvalid) { $postfields['licensekey'] = $licensekey; $postfields['domain'] = $_SERVER['SERVER_NAME']; $postfields['ip'] = $usersip; $postfields['dir'] = dirname( __FILE__ ); if ($check_token) { $postfields['check_token'] = $check_token; } if (function_exists( 'curl_exec' )) { curl_init( ); $ch = ; curl_setopt( $ch, CURLOPT_URL, $whmcsurl . 'modules/servers/licensing/verify.php' ); curl_setopt( $ch, CURLOPT_POST, 1 ); curl_setopt( $ch, CURLOPT_POSTFIELDS, $postfields ); curl_setopt( $ch, CURLOPT_TIMEOUT, 30 ); curl_setopt( $ch, CURLOPT_RETURNTRANSFER, 1 ); curl_exec( $ch ); $data = ; curl_close( $ch ); } else { fsockopen( $whmcsurl, 80, $errno, $errstr, 5 ); $fp = ; if ($fp) { $querystring = ''; foreach ($postfields as ) {[0];[1]; $v = ; $k = ; $querystring .= '' . $k . '=' . urlencode( $v ) . '&'; } $header = 'POST ' . $whmcsurl . 'modules/servers/licensing/verify.php HTTP/1.0'; $header .= 'Host: ' . $whmcsurl . ''; $header .= 'Content-type: application/x-www-form-urlencoded'; $header .= 'Content-length: ' . @strlen( $querystring ) . ''; $header .= 'Connection: close'; $querystring; $header .= ; $data = ''; @stream_set_timeout( $fp, 20 ); @fputs( $fp, $header ); @socket_get_status( $fp ); $status = ; while (( !@feof( $fp ) && $status )) { @fgets( $fp, 1024 ); $data .= ; @socket_get_status( $fp ); $status = ; } @fclose( $fp ); } } if (!$data) { date( 'Ymd', mktime( 0, 0, 0, date( 'm' ), date( 'd' ) - ( $localkeydays + $allowcheckfaildays ), date( 'Y' ) ) ); $localexpiry = ; if ($localexpiry < $originalcheckdate) { $localkeyresults; $results = ; } else { $results['status'] = 'Invalid'; $results['description'] = 'Remote Check Failed'; return $results; } } preg_match_all( '/<(.*?)>([^<]+)<\/\1>/i', $data, $matches ); $results = array( ); foreach ($matches[1] as ) { [0]; [1]; $v = ; $k = ; $results[$v] = $matches[2][$k]; } if ($results['md5hash']) { if ($results['md5hash'] != md5( $licensing_secret_key . $check_token )) { $results['status'] = 'Invalid'; $results['description'] = 'MD5 Checksum Verification Failed'; return $results; } } if ($results['status'] == 'Active') { $results['checkdate'] = $checkdate; serialize( $results ); $data_encoded = ; base64_encode( $data_encoded ); $data_encoded = ; $data_encoded = md5( $checkdate . $licensing_secret_key ) . $data_encoded; strrev( $data_encoded ); $data_encoded = ; $data_encoded = $data_encoded . md5( $data_encoded . $licensing_secret_key ); wordwrap( $data_encoded, 80, ' ', true ); $data_encoded = ; $results['localkey'] = $data_encoded; } $results['remotecheck'] = true; } unset( $postfields,$data,$matches,$whmcsurl,$licensing_secret_key,$checkdate,$usersip,$localkeydays,$allowcheckfaildays,$md5hash ); return $results; $file = 'license.txt'; explode( '', file_get_contents( $file ) ); $lines = ; $lines[0]; $licensekey = ; $localkey = '9tjIxIzNwgDMwIjI6gjOztjIlRXYkt2Ylh2YioTO6M3OicmbpNnblNWasx1cyVmdyV2ccNXZsVHZv1GX zNWbodHXlNmc192czNWbodHXzN2bkRHacBFUNFEWcNHduVWb1N2bExFd0FWTcNnclNXVcpzQioDM4ozc 7ISey9GdjVmcpRGZpxWY2JiO0EjOztjIx4CMuAjL3ITMioTO6M3OiAXaklGbhZnI6cjOztjI0N3boxWY j9Gbuc3d3xCdz9GasF2YvxmI6MjM6M3Oi4Wah12bkRWasFmdioTMxozc7ISeshGdu9WTiozN6M3OiUGb jl3Yn5WasxWaiJiOyEjOztjI3ATL4ATL4ADMyIiOwEjOztjIlRXYkVWdkRHel5mI6ETM6M3OicDMtcDM tgDMwIjI6ATM6M3OiUGdhR2ZlJnI6cjOztjIlNXYlxEI5xGa052bNByUD1ESXJiO5EjOztjIl1WYuR3Y 1R2byBnI6ETM6M3OicjI6EjOztjIklGdjVHZvJHcioTO6M3Oi02bj5ycj1Ga3BEd0FWbioDNxozc7ICb pFWblJiO1ozc7IyUD1ESXBCd0FWTioDMxozc7ISZtFmbkVmclR3cpdWZyJiO0EjOztjIlZXa0NWQiojN 6M3OiMXd0FGdzJiO2ozc7pjMxoTY8baca0885830a33725148e94e693f3f073294c0558d38e31f844 c5e399e3c16a'; if (!file_exists( 'includes/licensevalidator.php' )) { exit( 'license validator is missing....' ); } require_once( 'includes/licensevalidator.php' ); if (!empty( $acHash )) { $toCheck = 518; if ($acHash == md5( date( 'Y-m-d A', strtotime( 'now' ) ) . 'Active-Site-Validated-For-' . urlencode( $_SERVER['HTTP_HOST'] ) )) { $___EZY___wbValid______ = 'active'; $toCheck = 517; } else { if ($acHash == md5( date( 'Y-m-d A', strtotime( 'now' ) ) . '-INVALID-For-' . urlencode( $_SERVER['HTTP_HOST'] ) )) { $___EZY___wbValid______ = 'invalid'; } else { if ($acHash == md5( date( 'Y-m-d A', strtotime( 'now' ) ) . '-EXPIRED-For-' . urlencode( $_SERVER['HTTP_HOST'] ) )) { $___EZY___wbValid______ = 'expired'; } else { if ($acHash == md5( date( 'Y-m-d A', strtotime( 'now' ) ) . '-SUSPENDED-For-' . urlencode( $_SERVER['HTTP_HOST'] ) )) { $___EZY___wbValid______ = 'suspended'; } } } } } else { $toCheck = 518; } if ($toCheck == 1) { check_license( $licensekey, $localkey ); $results = ; fopen( 'includes/licensevalidator.php', 'w' ); $fp = ; if (!$fp) { exit( 'licensevalidator missing.....' ); } if ($results['status'] == 'Active') { md5( date( 'Y-m-d A', strtotime( 'now' ) ) . 'Active-Site-Validated-For-' . urlencode( $_SERVER['HTTP_HOST'] ) ); $md5HASH = ; $phpWrite = '<? $acHash = "' . $md5HASH . '"; ?>'; fwrite( $fp, $phpWrite ); $___EZY___wbValid______ = 'active'; } else { if ($results['status'] == 'Invalid') { md5( date( 'Y-m-d A', strtotime( 'now' ) ) . '-INVALID-For-' . urlencode( $_SERVER['HTTP_HOST'] ) ); $md5HASH = ; $phpWrite = '<? $acHash = "' . $md5HASH . '"; ?>'; fwrite( $fp, $phpWrite ); $___EZY___wbValid______ = 'Your License is Invalid'; } else { if ($results['status'] == 'Expired') { md5( date( 'Y-m-d A', strtotime( 'now' ) ) . '-EXPIRED-For-' . urlencode( $_SERVER['HTTP_HOST'] ) ); $md5HASH = ; $phpWrite = '<? $acHash = "' . $md5HASH . '"; ?>'; fwrite( $fp, $phpWrite ); $___EZY___wbValid______ = 'Your License is Expired'; } else { if ($results['status'] == 'Suspended') { md5( date( 'Y-m-d A', strtotime( 'now' ) ) . '-SUSPENDED-For-' . urlencode( $_SERVER['HTTP_HOST'] ) ); $md5HASH = ; $phpWrite = '<? $acHash = "' . $md5HASH . '"; ?>'; fwrite( $fp, $phpWrite ); $___EZY___wbValid______ = 'Your License is Suspended'; } } } } } if ($___EZY___wbValid______ != 'active') { exit( $___EZY___wbValid______ ); } 0 Quote Link to comment Share on other sites More sharing options...
