Smarty problem
wdele
I'm having a problem with my template. This is the code that's not working:
<div id="tabs">
   <ul class="nav nav-tabs" data-tabs="tabs">
       <li id="tab1nav" class="active"><a href="#tab1" data-toggle="tab">{$LANG.information}</a></li>
       {if $modulechangepassword}<li id="tab2nav"><a href="#tab2" data-toggle="tab">{$LANG.serverchangepassword}</a></li>{/if}
       {if $downloads}<li id="tab3nav"><a href="#tab3" data-toggle="tab">{$LANG.downloadstitle}</a></li>{/if}
       <li id="tab4nav"><a href="#tab4" data-toggle="tab">{$LANG.clientareahostingaddons}</a></li>
       {if $packagesupgrade || $configoptionsupgrade || $showcancelbutton || $modulecustombuttons}<li class="dropdown"><a class="dropdown-toggle" data-toggle="dropdown" href="#">{$LANG.productmanagementactions}</a>
       {if $groupname eq 'Web Development'}<li id="tab5nav"><a href="#tab5" data-toggle="tab">CMS</a></li>{/if}
           <ul class="dropdown-menu">
               {foreach from=$modulecustombuttons key=label item=command}
               <li><a href="clientarea.php?action=productdetails&id={$id}&modop=custom&a={$command}">{$label}</a></li>
               {/foreach}
               {if $packagesupgrade}<li><a href="upgrade.php?type=package&id={$id}">{$LANG.upgradedowngradepackage}</a></li>{/if}
               {if $configoptionsupgrade}<li><a href="upgrade.php?type=configoptions&id={$id}">{$LANG.upgradedowngradeconfigoptions}</a></li>{/if}
               {if $showcancelbutton}<li><a href="clientarea.php?action=cancel&id={$id}">{$LANG.clientareacancelrequestbutton}</a></li>{/if}
               {if $groupname eq 'Hosting'}<li><a href="http://{$domain}:2083" target="cpanel">cPanel (advanced)</a></li>{/if}
           </ul>
       </li>{/if}
   </ul>
</div>
Everything works, except 'Management Actions' refuses to open when
but it does when
$groupname eq SomethingElse
What's the problem?
- - - Updated - - -
Update: when I remove
it works again...
- - - Updated - - -
Update: after moving
to under the
<ul>
it works. Weird.
