Project Management permissions
stender
Hello
I am unable to find the set of permissions to allow a non-full administrator to have the ability to see to the addon module for Project Management, without giving the group/user too many permissions.
I created a "Technical Team" group and selected the more obvious ones Project Management widget and all possible "view" permissions.
Does anyone have any ideas?
Thanks
Alex
  • 9 months later...
Yes, you want to go to Configure the addon, Project Management in your Admin area and only check option for,
Allow Access to Settings for Full Administrator users.
Next create some Admin Roles and adjust settings WITHIN the Project Management settings.
Hello
Thanks
Alex
