Da1 Posted August 10, 2014 Share Posted August 10, 2014 Example: Stock is 100 and I sell 1, stock goes down to 99. I cancel the order, stock goes back up to 100. The problem is if I then delete the order I had cancelled, stock goes up to 101. Is there any way I can stop this from happening other than NOT deleting orders that have also cancelled? Note: If I simply delete the order without first cancelling it, stock control is OK but the cPanel account is NOT removed. 0 Quote Link to comment Share on other sites More sharing options...
Alex - Arvixe Posted August 10, 2014 Share Posted August 10, 2014 It sounds like a bug. I recommend you visit: http://www.whmcs.com/bugs and report it so it can be checked and fixed in a later version if that is the case. Until confirmed/fixed your options are probably to simply cancel the order and not delete it or to manually reset the stock control back to 100 after deleting the order. 0 Quote Link to comment Share on other sites More sharing options...
