Cloudflare and WHMCS bridge problems
bazil
I just finished the customization of my website with a custom WP+WHMCS theme using WHMCS Bridge. But when I go to my client area the background is blue while it should be white and also other stuff looks messed up. I located the problem being Cloudflare. When I pause my cloudflare the client portal looks like it should be.
Does anyone know what I need to change in Cloudflare so I can keep using Cloudflare to protect my website?
Are there any other issues with Cloduflare I should be aware about?
Hi bazil,
Can you send us a link to the messed up page and/or a screenshot? If I had to guess, based on the information provided, most likely some CSS or other element is not being loaded due to a mixed content situation (where CloudFlare might be serving the page over HTTPS, but other elements are not embedded as such).
We're always happy to help at help [at] cloudflare.com
