Xtreme Hosting Posted November 22, 2013 Share Posted November 22, 2013 Urgent! I have upgraded from 5.1.12 to 5.1.13 fine and tested ok then went to update to 5.1.14 and now just getting a blank page on everything in WHMCS. I have tried to re-download and replace the files again and still get the same message. Xtreme-Hosting.com/billing/ 0 Quote Link to comment Share on other sites More sharing options...
Xtreme Hosting Posted November 22, 2013 Author Share Posted November 22, 2013 Problem Corrected! 0 Quote Link to comment Share on other sites More sharing options...
hostEONS Posted November 22, 2013 Share Posted November 22, 2013 How did you fixed it? as even i'm having same issue 0 Quote Link to comment Share on other sites More sharing options...
hostEONS Posted November 22, 2013 Share Posted November 22, 2013 NVM fixed it 0 Quote Link to comment Share on other sites More sharing options...
mlew2 Posted November 22, 2013 Share Posted November 22, 2013 I think you both should say HOW you fixed the issue as you likely are not the only two with the issue 0 Quote Link to comment Share on other sites More sharing options...
