mlody.1039 Posted November 6, 2013 Share Posted November 6, 2013 Hello. I have bought WHMCS for Gamepanelx i have follow all documentation but fail i have error when I want approve user or create service I have done everything correct even rayn check it and said whmcs and gampanelx configuration its prefect but I got this error Order Accept Encountered Problems No API key specified (&key=) Rayn told be its Curl error but I can't find way to fix it I'm running CentOs 6 32 bit and I have Curl Installed any Ideas?? Best Regards mlody.1039 0 Quote Link to comment Share on other sites More sharing options...
IgnitionHosting Posted November 6, 2013 Share Posted November 6, 2013 Have you put the API key into your server configuration? 0 Quote Link to comment Share on other sites More sharing options...
mlody.1039 Posted November 6, 2013 Author Share Posted November 6, 2013 yes. as I said Rayn Gamepanelx Developer check whmcs config and its all right... but its not working... Best Regrads mlody.1039 0 Quote Link to comment Share on other sites More sharing options...
mlody.1039 Posted November 7, 2013 Author Share Posted November 7, 2013 Hello. Developer of Gamepanelx said its whmcs issue maybe because some update may block whmcs hmmm is there any way to fix it Rayn (GPX Developer) check if the module get api and works but whmcs have some issue and not working... Best Regards mlody.1039 0 Quote Link to comment Share on other sites More sharing options...
