2Checkout Module not working with multi-currency
Using v 5.1.7 the 2Checkout module is not working correctly when more than one currency is enabled - it just uses the default currency of the 2CO account.
Example:
2CO account currency: USD
Product: EUR 100 / USD 130
If a client orders in EUR, the module sends only the price ("100") without currency to the 2CO payment gateway - which results in "USD 100" according to 2CO default currency.
According to 2CO support, only the parameter currency_code has to be set:
WHMCS is not open source so only they can create the modules so I can only suggest contacting a WHMCS developer to find out if they can create a new payment module with the ability to pass in the "currency_code" parameter for you to force the currency change. 2Checkout supports the following currencies only: ARS, AUD, BRL, GBP, CAD, DKK, EUR, HKD, INR, ILS, JPY, LTL, MYR, MXN, NZD, NOK, PHP, RON, RUB, SGD, ZAR, SEK, CHF, TRY, AED, USD.
Could a WHMCS developer please add this single line of code to the 2CO payment module ?
Thanks !
